Please help. Everything's Chugging.
7 minutes ago, Flashie said:For the past almost month and a half i've laid off of playing my favourite game GTA Online because i cannot watch videos on my second monitor while playing it anymore as i've been doing for the past 4 years on this same build of mine.
I have an MSI GTX 970 Armour, 16GB of DDR3 1600MHz Kingston HyperX RAM, and an i7-4790k all stock with no overclocks done by me.
Whenever i alt tab out of GTA, the chugging stops, But as soon as i'm in GTA, everything goes to ****. Videos on the second monitor start buffering and stumbling forward more than a learner in a manual car.
I've had it so bad that even my keyboard's software has had trouble controlling the LED's (it made for a pretty cool video though:
I suspect this is a big part of the problem im having. My game also happened to crash from the sheer lack of capability to continue the intense chugging, which is why you see the usage dropping so much.
No other programs were active at the time except for a single no-extensions-enabled tab of Brave Browser, and GTA Online. Some services running in the background like my corsair lighting, which makes no difference if i disable or enable it.
Please be my saviour.
I fired up Afterburner and took stats as i alt tabbed between GTA and my video. The chugging stops/starts depending on which of the two are the active window.
CPU temps are at 80 (Nothing i can do. Africa's a bi*ch this time of year).
I want to know why does only 2 of my CPU/Threads do all of the active work (maxed out usage while the rest is basically 0%)
Go into your BIOS and default every setting. If that does not work make sure your in your Power Option the Processors Power is 100% on the Maximum. OR the worst is that your CPU or GPU is degraded and need replaced. Try get another or borrow a CPU and GPU and retest.
