Hey! So my current situation is upgrading my old pc, current specs are i5-4460k gt 1030 12 gb (ddr3) and I believe a 450 power supply. I need a GPU that’s capable of streaming and playing games at low to medium settings if not more. I don’t have much of a budget but I’ll keep it at 150. And I also am trying to find one that don’t need a pin connector if possible?
https://linustechtips.com/topic/1017471-help/
Well the streaming part has lots to do with your CPU horsepower.  Anyhow.  Get a 1050 Ti .... you should be able to find one for under your budget.  good luck
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1017471-help/#findComment-12156229
