Hey guys and gals,
I desperately need your help. Before we start here are my specs
i7 8700k
EVGA GTX 1080ti Black
16gb Corsair RGB DDR4 Ram
MSI z370 Gaming Plus
Corsair 650w power supply
2 500gb SanDisk SSDs
1 500gb Samsung HDD
My issue is that my PC is freezing during gaming sessions with no errors and I can NOT figure out why. I play Dota 2, CSGO, Rocket League, and all of my Oculus Rift games without crashing. When I play COD Black ops 4, Sea of Thieves, Fortnite, Escape from Tarkov, my PC screen freezes with audio continuing. I can NOT alt+f4 out and I have to manually reboot my computer. I have tried so many things. I have wiped my windows and drives and started fresh to no avail, I have rolled back drivers, I have installed using DDU. I have ran CPU and GPU stress tests and no freezing there. I have ran memtest86 with 0 errors. I do have an issue however when I run timespy that my screen freezes just like when I play games. I am about to give up and start replacing hardware unless someone knows a better solution. I am assuming that it is a bad PSU or GPU but I don't have extras to throw in sadly.
https://linustechtips.com/topic/1016591-possible-gpu-failure-help-me-please/
Honestly, I would put this down to PSU alone. I've had the same issue with a 650W Bronze PSU, when I changed to a 750W Gold, my freezing, poor performance and stuttering disappeared completely. However, I would also get it sorted quickly or don't use your PC until you've replaced the PSU. Using a bad PSU can cause your GPU to fail quickly or even kill it completely.
IT Manager working in the Education sector.
1 minute ago, Brennan_Price said:
Honestly, I would put this down to PSU alone. I've had the same issue and when I changed my power supply suddenly I stopped getting the errors. However, I would also get it sorted quickly or don't use your PC until you've replaced the PSU. Using a bad PSU can cause your GPU to fail quickly or even kill it completely.
^^^ What model PSU is it? Corsair has budget units that I wouldn't trust to drive such expensive hardware, and then also literal godlike units that are some of the best in the business.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
5 minutes ago, MrPulsee said:
I want to say it is a modular Cx 650. I have thought about changing PSU out ASAP but I wanted to make sure it wasn't something else first.
If it's the older green label CX unit I'd swap it out and see if that's the issue. Though a dude on a discord server I'm in has powered some pretty hungry hardware off a green label CX with no issues. Considering a new PSU is probably the single cheapest piece to buy for troubleshooting your rig though, I'd start with that.
Mouse: EVGA X17
That PSU is not the worst thing in the world but I reckon it cannot provide enough power across your whole system. Upgrade to something that can provide more power across all of its rails and make sure it can provide more stability and you'll probably be alright :) Can't go wrong with a 750W Gold rated PSU.
Wattage wise he should be fine though, I've ran a 980 Ti off a CX450M and an R7 2700X and Vega Frontier Edition off a 650W, for an i7 and 1080 Ti 650W is fine, 550W would do the job too.
Mouse: EVGA X17
Yeah true, I just feel that something slightly more powerful will decrease the load on the PSU and therefore make his system more stable plus last longer. Not needed though of course :)
I think the efficiency curve for a PSU changes depending on the unit, but they all can stably output their rated wattage, the efficiency rating just shows how much they pull from the wall to supply that wattage to the PC, higher rated units lose less to inefficiency. Stability shouldn't be an issue unless your hardware tries to pull more wattage than the PSU can supply.
Mouse: EVGA X17
Well, I think I have ruled out PSU, bought the new one and got it up and running and I started to artifact in Escape From Tarkov. Any idea on how to go about getting a RMA from EVGA or Newegg?
For EVGA you should be able to chat with their support guys on their site during normal business hours, they're freaking amazing and usually solve stuff in just a few minutes. Heck my friend will sometimes just message them with random questions about sorting out performance issues and they help him out (he had an EVGA 1050 Ti, just got a Zotac 1060 though).
Mouse: EVGA X17
