Hey,
Is it possible get 3mm RGB LEDs? I know that about a year ago, it wasn't, but after some search on google, it seems like is. No idea if they are 3mm tho. I need 3mm LEDs for some modification, I'm going to make to some XSPC waterblocks (only 3mm will fit).
Another questing. If I connect an on/off switch to the common cathode, will it turn the led on and off, or doesn't it work like that with RGB LEDs?
My setup: i5 3570K  - Corsair H100i - MSI Z77 GD65 - 256 GB Samsung 840 pro SSD - Corsair AX760i - Gigabyte GTX 670 Windforce 2GB - 4x4 GB Crucial Ballistix Tactical Tracer RAM - Corsair Carbide 500R (modded side window)
https://linustechtips.com/topic/101622-3mm-rgb-led/
Just make sure to buy the RGB LEDs that have 4 prongs. That way you can control the colour. If you get 2 prongs, it'll alternate at a factory set speed and flash through the whole colour spectrum.
Yeah, that's my problem I'm not sure if I can get a 3mm RGB LED with 4 prongs.
https://linustechtips.com/topic/101622-3mm-rgb-led/#findComment-1358717
Alibaba is a site that connects you with manufactures, its not a storefront, so unless you are planning on ordering in bulk you don't want to shop from there. I've ordered a few things in bulk thru Alibaba and haven't had any issues, but its all about who you end up dealing with and Alibaba cannot control that, just make sure they have a good reputation before getting too excited.
I can find plenty of 5mm 4 pin RGBs, but not finding anything for 3mm other than Alibaba... https://www.sparkfun.com/products/9264
Starting to look like a bulk buy could be profitable if there was demand lol.
https://linustechtips.com/topic/101622-3mm-rgb-led/#findComment-1402684
