@Billy Pilgrim Ive been asking this question on and off for about a year and get mixed results.  Some say yes and some say no.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1016205-m2-cooling-necessary/#findComment-12144563
More often than not these "heatsinks" end up trapping heat from graphics cards and heating the SSD's, so they are mostly useless only for looks.
NAND is fine and performs better being hot, the controller though is the complete opposite.
Unless you are constantly writing and reading to the SSD hard all day long a heatsink that actually removes heat wont do anything as you wont hit throttle temps.
Samsung NVMe SSD's and some others actually have a super thin layer of copper on the sticker which is enough to deal with the heat for 99.9% of use cases.
https://linustechtips.com/topic/1016205-m2-cooling-necessary/#findComment-12144567
I've read about this copper thing some weeks ago, but I didn't feel like peeling the sticker of my Samsung SSD. However, now I'm kinda curious about the temps and HWinfo only gives one temperature and I don't know wher that is reading from. I'll go stick a thermalprobe on a few spots on my SSD and run a stresstest, I'll post the temps in half an hour or so.
EDIT: It'll take a little longer than half an hour, it already took me 15 minutes to get the probe on the SSD, when I post pictures you'll see what a pain in the ass it is to get it there.
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
https://linustechtips.com/topic/1016205-m2-cooling-necessary/#findComment-12144621
