Ok so i am making a budget build and I had bought this PC for really cheap and i am looking to upgrade it on a budget.
Processor
AMD FX(tm)-8350 Eight-Core Processor
Video Card
AMD Radeon HD 6800 Series
RAM
8.0 GB - DDR3
Operating System
Microsoft Windows 10 (build 17134), 64-bit
Those are my specs, I plan on keeping my 8350 but im looking to upgrade my GPU and Ram, any recommendations on a good budget GPU that will work with my 8350. Thanks!
https://linustechtips.com/topic/1015682-i-need-help/
GTX 1050 ti from eBay would do well, draws very little power and quite the performer.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1015682-i-need-help/#findComment-12140410
