I finally upgraded my system by giving it an actual dedicated gpu instead of using the built in graphics that came in with my ryzen 5 2400g. The graphics card is installed but in order to make my pc use the dedicated gpu I had to disable built in graphics through my bios. Now my question is am I doing this right? Could I have leave the built in graphic option on in the bios? Also my last question is do I proceed to install the drivers for my gpu or uninstall the drivers for my 2400g then install the drivers?
https://linustechtips.com/topic/1015014-gpu-driver-help-and-gpu-questions/
Should be fine to install the card, connect the display cable to it and run just fine.
Shouldnt be required to do anything else. Aside from installed the latest drivers for the card.
Not plugging my monitor into the GPU instead of the IO in the back is a mistake I've made before.
Leave the built in gpu settings as is and don't touch the drivers. You should just plug in the GPU, wire it up and then download and install the latest driver for your GPU.
For Nvidia you'll download GeForce and it makes it really easy. AMD GPU's I am not really knowing. I would go to the manufactures website and go from there.
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
