So I built my pc yesterday and my mother board has inconvenient slots for where my cable management slots are on case any ideas on how to clean up
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/
5 minutes ago, Cyberspirit said:
There should be a hole above the Motherboard for the CPU power cable. What case do you have?
the motherboard takes up the whole case and no room apart from the otherside of the case and i have coolermaster masterbox lite 5 and msi b450 gaming pro carbon ac
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134488
18 minutes ago, beyonddc said:
What is the brand and model of your motherboard?
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134489
Well, that's a horrible design. Then, I'd say you could route the CPU power cable where you routed the Motherboard power. Should be able to reach no problem.
Also, you don't need the extra 4-pin CPU power plugged in. The 8-pin should be enough.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134508
I KEPT GETTING Blue screens untill i plugged that in
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134551
29 minutes ago, Cyberspirit said:
Oh weird, nevermind then.
unplugged the second cable and hopefully no blue screens, also i found a tiny hole at the top and put the 8 pin through that and re routed my gpu cable and it looks alot cleaner thanks now all i need is some rgb lights and would you happen to know the software that controllers the rgb fans on my coolermaster masterbox lite 5 case as i cant find it
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134667
18 minutes ago, Cyberspirit said:
Nice. Do you want to get RGB strips or, do you just want to control the RGB on your GPU and your Motherboard?
want to control the rgb on motherboard and my coolermaster rgb fans and in future want to get led strip light rbg
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134747
For the Motherboard, you can use MSI's Mystic light software which can be found on the Motherboard's support page.
Here's a direct link if you use Windows 10 64bit: http://download.msi.com/uti_exe/mb/Mystic_Light_3.zip
Otherwise, you can just go here and select your OS: MSI B450 gaming pro carbon ac
Not sure if those fans can be controlled though. Do they have any other cable besides the power?
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134784
No they said they where rgb and i can see the lights but all it had was a cable that connected to a molex and the actual fans where linked to a splitter which went into the rgb fan slot
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134870
4 minutes ago, Cyberspirit said:
So, did the case come with a fan hub or, did you connect them to your Motherboard?
it came with the usual usb 3.0 and stuff it also had a 3 fans leads that connected to a coolermaster adapter which plugged into my rgb motherboard slot and also a plug with 2 golden thick pins in it that i connected to my molex cable
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134959
16 minutes ago, Cyberspirit said:
Oh, I see then, you might be able to control them through MSI Mystic light. Do they show up in there?
No its just motherboard sadly
PSUGigabyte P650B
https://linustechtips.com/topic/1014892-cable-management/#findComment-12134982
