Okay, I have a few questions.
Does it matter what OS I have?
Will this CPU work with this MOBO?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113330
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157468
Does that MOBO support 3 or 4 way Xfire?
How many watts should my PSU be if I want to litecoin mine with 280X?
2-way X fire?
3-way?
4-way?
Edit: What would you change about this build?
http://pcpartpicker.com/p/2zPEY
https://linustechtips.com/topic/101447-lite-coin-help/
The CPU has no GPU built in. Get one with one. As for the board, it will work with the CPU.
It can do 2-way CrossFire.
https://linustechtips.com/topic/101447-lite-coin-help/#findComment-1356125
First off it is spelled Litecoin.(sorry just bothers me!) I think you have missed your window to make a mining rig, currently a system like that would not pay itself off.
http://bitcoinwisdom.com/litecoin/difficulty
One overclocked r9 280x mines at ~700KH/s this is based off of this chart. From my experience this is a little bit high.
https://litecoin.info/Mining_hardware_comparison
If you look at the chart, two r9 280x would be making $261 a month, not very much considering how much money you put into a mining rig. Along with that the amount of power it will use will be pretty expensive, looking at around $80 a month. Finally the difficulty of mining is increasing rapidly so it will be making a lot less than the predicted 261 a month. I would suggest investing it in Litecoin directly since Litecoin is at a low, currently it is at $24, but it will definitely rise.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/101447-lite-coin-help/#findComment-1356167
It will NOT cost that much in electricity. I have 8 R9 280X's and 3 R9 290's and I pay $230/month in electricity :P
Granted, I don't know the price of power where you or the OP live.
https://linustechtips.com/topic/101447-lite-coin-help/#findComment-1356239
I had it doubled, it would coast about 40.
http://www.coinwarz.com/calculators/litecoin-mining-calculator/?h=1400&p=500.00&pc=0.10&pf=0.00&d=3891.34232183&r=50.00000000&er=0.02913144&hc=0.00
https://linustechtips.com/topic/101447-lite-coin-help/#findComment-1356256
