8700k Temps
Go to solution Solved by vK 3 1 RON,
Just now, Azriel said:
 @vK 3 1 RON and @r2724r16 the two Java are Minecraft as much as I don't want to admit it. Would that lead to the temps I have?
Those temps are fine for gaming - pretty sure minecraft is CPU intensive too so those temps seem rather normal to me. You could try shutting down your system, waiting for the CPU to cool down fully before turning it back on - not opening anything else up and just leave it to get to an 'idle' temperature which shows us what kind of thing you're looking at without any 'stress' or 'load' on your system :)  But I wouldn't be worried about 45-50 C. I'm currently at 44C right now with 4 google chrome tabs open, steam open, plus some other background stuff :)
45-50C at idle is a bit high, but nothing to worry about.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1014135-8700k-temps/#findComment-12128629
Just now, vK 3 1 RON said:
Those 2 Java runtimes don't seem to be 'idle' maybe he's running something like Minecraft in the background?
https://linustechtips.com/topic/1014135-8700k-temps/#findComment-12128652
https://linustechtips.com/topic/1014135-8700k-temps/#findComment-12128657
Yo thank you so much! I appreciate it :D
https://linustechtips.com/topic/1014135-8700k-temps/#findComment-12128661
