I built this computer to replace my laptop. I seem to have bad luck with laptops, probably because I play too many games... :) I spent about as much as I did on my last laptop. I've had the machine for about 4 months and everything runs just fine. My hope is that this build will last me 5 years or longer before I start needing to replace things. I'm very pleased. The power supply that comes with the case is not powerful enough for me so the only down side is that I have a spare power supply sitting around.
Let me know what you guys think.
PC Parts.docx
https://linustechtips.com/topic/1013058-first-pc-build/
PC Parts.docx
Good Job, Whats the spec?
https://linustechtips.com/topic/1013058-first-pc-build/#findComment-12120488
The Z370 board is overkill for the i7 8700 since it's not unlocked (unless you're doing BCLK), but it's probably got some good features. Also, link a pcpartpicker list so that it's easier to see your parts list, or add it to your signature via your account settings in the top right
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1013058-first-pc-build/#findComment-12120540
