hello there, recently my brother went to college and he gave me his old PC. But it is not very good, i wanna play GTA V but only 35-45 fps and have to lower my resolution. I only have $40 to upgrade it, how should I?
Specification:
i7-5775C
Iris Pro Graphics 6200
4 x 1GB Crucial RAMs
Foxconn H97M Plus
Western Digital 750GB Scorpio Blue
Corsair TXM550M power supply
Rosewill RANGER-M
https://linustechtips.com/topic/1012764-upgrade-advice/
Specification:
i7-5775C
Foxconn H97M Plus
Rosewill RANGER-M
I am surprised you get that much FPS. RAM isn't ideal but its quad channel. And it would limit your performance but first upgrade your GPU. Your CPU is good enough.
However since you have only 40$ you should try to get a used GPU like a Radeon R9 or something similar. But your next step should be switching those 4 sticks of RAM and get 8GB of DDR3 1600 RAM (4x2 or 8x1) for around 40-50$ and sell the remaining RAM.
https://linustechtips.com/topic/1012764-upgrade-advice/#findComment-12118518
its dual channel, chipset supports dual channel only
Main Rig: CPU Intel Xeon X5660 (4.55Ghz @ 1.45v) / MOBO Asus ROG Rampage III Extreme / RAM 16GB Corsair Vengeance LPX1866 MHz / CPU COOLER ID-COOLING Frostflow+ 240 / GPU EVGA Titan X Hybrid (+630 core + 400 memory) / CASE Cooler Master CM 690 II Advanced + transparent side panel / SSD Crucial M550 512GB / PSU Cooler Master Silent Pro Gold 1200W / DISPLAY 1440p monitor / KEYBOARD Topre Realforce RGB / MOUSE Corsair Glaive Aluminum RGB / SOUND Creative Labs. X-Fi SoundBlaster Elite Pro / ROUTER Netgear R9000 X10 Wireless ad / OS Windows 10 Pro / DRIVING WHEEL Logitech G27
Web Server Rig: CPU 2x Intel Xeon X5680 / MOBO Supermicro X8DTL-i / RAM 64GB (2X32GB) SK-Hynix ECC LRDIMMs / CPU COOLER ID-COOLING Frostflow+ 120 + Corsair H50 AIO / GPU MSI GTX 1070 Gaming X (+250core +300 memory) / CASE NZXT Lexa S / SSD Kingston 120GB / HDD 4 x 3TB WD RAID 6 / PSU Enermax MaxRevo 1500W / DISPLAY 900p monitor / KEYBOARD Logitech / MOUSE Logitech
Actually Portable Laptop: HP Spectre x360 15' (Late 2018) / i7-8750H, 16GB RAM, 512GB SSD, GTX 1050Ti MaxQ, 4K Display / KEYBOARD Ducky One 2 Mini / OS Linux Mint 19 Cinnamon / WIRELESS ADAPTER NETGEAR A6210 USB 3.0
Bed Laptop: ASUS VIVOBOOK 15 / i5-8250U, 8GB RAM, 1TB Toshiba HDD, UHD 630, 1080P Display / OS Linux Mint 19 Cinnamon
Backup Rig: CPU Intel Xeon X3470 (4Ghz @ 1.4v) / MOBO MSI P55-GD80 / RAM 16GB HyperX 1600Mhz / CPU COOLER ID-COOLING Frostflow+ 120 / GPU Sapphire R9 270X (+150 core + 200 memory) / CASE Cooler Master Elite 343 SSD Crucial MX150 250GB / PSU Seasonic SS430-GB / KEYBOARD Logitech G910 Orion Spark / MOUSE Logitech / DISPLAY Dell SE2417HGR / OS Windows 10 Pro / WIRELESS ADAPTER
TP-LINK Archer T6E PCI-E
Server 1: DELL POWEREDGE 1950 / 2x Intel Xeon E5450, 16GB ECC, 4x 3TB Western Digital (Various) 7200RPM SATA HDD in RAID 6, GT 640 / DISPLAY Lenovo L2251p
Server 2: DELL POWEREDGE 1950 / 2x Intel Xeon E5420, 8GB ECC, 2 x 160GB SAS, GT 210
https://linustechtips.com/topic/1012764-upgrade-advice/#findComment-12118533
3 minutes ago, Tarun10 said:
Oh so his 4 sticks are running in separate dual channels??
yes
https://linustechtips.com/topic/1012764-upgrade-advice/#findComment-12118662
