Hi everyone, I want to create a good profile for my bios and save it since Asus doesn't update my board anymore and I think its time to do it.
First of all, I want to overclock if I can the i5.
I saw a video some days ago, that its possible but I don't know how to on my board and if I can Here
Here are some screenshots from my bios default settings, I hope we can tweak together this.
Here you can see my processor and ram
i5-4690
b85m-g r2.0
8gb ram ddr3 kingston hyperx
4gb ram ddr3 kingston normal (green one)
This is what default looks like and my from always settings
And from here I don't change anything else.
Under these settings
DRAM Timing
Digi +
CPU Power Management
CPU Config
I hope you can guide my today ^^
https://linustechtips.com/topic/1012131-help-overclocking-cpu/
21 minutes ago, amusedschrodinger said:
Non K cpu aren't meant to be overclocked. You can try tinkering with the baseclock if you want but that will mess with other components as well.
I know, at least I want to know what can improve in my bios.
https://linustechtips.com/topic/1012131-help-overclocking-cpu/#findComment-12113977
