Hey everyone, just yesterday I had to replace my motherboard so i went with a Asus Prime x470-PRO. I have two LED strips one from cablemod with the remote and another from the Captain 240EX. I have them both hooked to their own RGB header but i cannot sync them together no matter what i try. Ive tried reinstalling the program completely, turning off RGB in the bios and than turning it back on. I have both options for the strips in Aura but i cannot sync them together (change both of their colors/patterns etc. at the same time. Any help would be greatly appreciated! Thanks! Ill attach some photos for more help if thats possible :)
https://linustechtips.com/topic/1011719-asus-aura-sync-help/
You prob plugged them in wrong, flip the orientation of the plug in the motherboard.
  • CPU 12900k   Motherboard Asus z690 prime RAM 32gb gskill 3200 trident z GPU Msi suprim RTX3080 wekwb block Case 011 dynamic PSU Evga gq  850w 1tb NVME m.2 boot drive
https://linustechtips.com/topic/1011719-asus-aura-sync-help/#findComment-12118535
