How many Thermaltake Riing Trio fans could I run off a Thermaltake Pro Sync controller?
Solved by Inelastic,
I've been using one with my fans. It's 9 fans split into 3 channels. Each channel has its own speed control that can be plugged into a mobo header. The 3 fans on a single channel will have its speed controlled identically. The lighting is controlled by one source, so each channel will be identical to the other. That means that fan port 1 on channel 1 will be the same as fan port 1 on channel 2, etc. If you want, you can plug all three fan controllers into one header, controlling all 9 fans off the single header, since it doesn't actually draw from it to power the fans.
