Ok so I am taking apart my hp pavilion dv9000 laptop. And it has been over heating lately so I was going to clean it out and put some new thermal paste(arctic mx-4) on the cpu and gpu... But when I took the heatsink off of the GPU there was no thermal paste! So is it ok if I put some on? Or will I change the molecular weight of an atom and somehow blow my laptop up?
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/10114-thermal-pastelaptop-gpu-help/
Never mind I did anyway....
Did you check temps before and after to see what the difference is?
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
NO. We're going to have a convo about it anyway.
I did it twice. PITA both times. Just make sure you spread it out and don't use the pea method.
P95 temps went down from 111C to 80C for one of the notebooks. Yes 111C said HWMonitor :P
Well actually I have not got it all back together yet.We will see...it was like 11 last night and I still had 20 screws.So I called it.
Ok so I got it all back together...And before I redid everything it was overheating and black screening or would not even boot. Now it is running good:0 I have to put a new OS on it before I can check my temps but I will let you peeps know when I find out:) Btw dont take apart a laptop without writing down where the screws go or without watching a tutorial first...
noted ;)
Desktop:  MSi GTX 680 Lightning - MSi Mpower Z77- i7 3770k - Asus Xonar DGX  - 16Gb Ares Ram - GX 750w PSU
Laptop: MSi GE 60 - GTX 765m - i74700MQ - 8gb ram
