Hi, I only recently been getting the DRIVER_POWER_STATE_FAILURE BSOD and it appears to happen randomly I analyzed the .dmp file with WhoCrashed? and this was the result:
On Sat 22.12.2018 12:56:36 your computer crashed
crash dump file: C:\WINDOWS\Minidump\122218-14796-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1AA0A0)
Bugcheck code: 0x9F (0x3, 0xFFFFE10033798BA0, 0xFFFFF800290677D0, 0xFFFFE10038E9F600)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
any hint on what this could be or how to fix it? Any help would be appreciated :)
https://linustechtips.com/topic/1011328-driver_power_state_failure-bsod/
