Just got a new Samsung CJG5 27" QHD 144Hz Monitor and seem to having a weird issue.
In games, when set at 1440p @144Hz = Stutters and frame freezes every couple seconds
when set at 1080p @144Hz= Fine
when set at 1440p@60Hz = Fine
Also tested several games and benchmarks, so it's not a program specific issue.
I've been tearing my hair out trying to solve this but haven't been able to. Even done a clean windows install to no avail. Any ideas?
System specs in summary : FX8320@4.4Ghz, MSI R9 290 4GB @Stock clock, Corsair 8GB DDR3 1600Mhz, 850W EVGA B2 PSU, Asus M5a99fx pro r2.0.  Connected via displayport with a cable that is 144hz qhd compatible.
Thanks a lot!
https://linustechtips.com/topic/1010682-high-refresh-rates-giving-problems/
15 minutes ago, mxk. said:
To me, it sounds like it could be the cable.
Hmm, strange because I read that with DP and HDMI cables, they either work or they don't - i.e I am seeing 144hz 1440p on graphics options.
The cable I'm using is here: https://www.amazon.co.uk/gp/product/B005H3Q59U/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I meant the cable might be a dud, or you understood that already? You have to have a specific type of HDMI for 144hz+1440p, and the monitor and cable have to be that HDMI type.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
I see what you're saying now. Yeah The monitor needs either HDMI 2.0 (which my r9 290 doesn't have) or DisplayPort and hence I am using Display port.
2 hours ago, Glenwing said:
How does it behave at 120 or 100 Hz?
I am still to conduct some more testing to check this and was planning to do it in the next couple of days - if is it is a gradual increase (i.e gets worse as the refresh rate increases) what do you reckon? Could it be pinned down to the monitor having no freesync technology?
Thanks a lot!
