few suggestions
1. the classic UpDATE yOUr bIOS ?
2. see if your gpu is being undervolted somehow
3. use msi afterburner and see if you can somehow improve the mhz by increasing the voltage limit and doing an oc
4. return it and buy a new one (if the above options fail)
8 minutes ago, Quintavious V said:
1060 (mobile 6gb)
on a laptop?
if so try;
1. plugging it into a wall
2. doing a hard shutdown, wait for the components to cool off, restart the laptop (sometimes laptops will start thermal throttling and stay throttled even after the temp issue has been resolved)
https://linustechtips.com/topic/1010120-1060-low-mhz/#findComment-12097119
1 minute ago, Happycowdance said:
few suggestions
1. the classic upDATE yOUr bIOS ?
on a laptop?
if so try;
i played yesterday and samee problem, fired up my laptop n still same problem
https://linustechtips.com/topic/1010120-1060-low-mhz/#findComment-12097122
how did you check GPU and VRAM clocks? At 550MHz core clock you wont be getting 70-80 fps at 1080p for sure.
Desktop benching:
https://linustechtips.com/topic/1010120-1060-low-mhz/#findComment-12097161
