So i the place i live wifi comes with the place and i have a wifi router thats set up in my kitchen. There is only one port available for a wired connection and thats running to my pc in my room but i want to get better wifi coverage in my room and the livng room. Ive been doing some research and im not sure if i just need to get a switch then i can run 2 wires to the living room and my bedroom to hook up a wifi extender of some sort( not sure the name) and then i can still run my wilred connection to my pc? I added  a pic of what im working with. the cable im using is on the right. not sure what the others are for but im guessing its just connections to other routers in the building.
https://linustechtips.com/topic/1009863-better-wifi-coverage-help/
Switch and a range extender sounds like a good option.
You could install a switch and an wireless AP, or get a cheap router, install a custom firmware and turn that into a wireless AP.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
