I have the steelseries siberia v2 and its uncomfortable. im trying to buy a headset, and ive decided on a corsair vengence 2000... would it be comfortable for someone with a big head? i wear hat size 7 3/4
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/10083-headset-for-a-big-head/
you already bought the vengeance 2000?
If he did, I guess he'll have to find out for himself lol
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/10083-headset-for-a-big-head/#findComment-109350
big head here. owns the corsair vengeance 2000. it is comfy, sounds decent enough that despite having audio technica headphones I use them almost daily
big caveat though. the sides crack. I'm on my third set now the upside though is after you pay to send them back to corsair they pay for every set back. they also make it convenient with no down time in between when you send it back to them.
edit: what aspect of the siberia was uncomfortable it is copied off a known comfortable design similar to the AKG and the audio technica ad700
if it is too tight tie a couple textbooks together and clamp your headphone on it to stretch it apart.
https://linustechtips.com/topic/10083-headset-for-a-big-head/#findComment-109708
the ear cups were small i guess.i should mention i wear glasses
https://linustechtips.com/topic/10083-headset-for-a-big-head/#findComment-110479
