Yes you can however I fail to see the point for a consumer level product unless you're running an X79 platform with quad SLI or Crossfire. I don't know the correct way however if I were to do it I would combine both of the either 7th or 19th pins - I can't remember which one is the PSU on pin - together so both PSU's start. That's about all there is to it really from what I'm thinking off.
https://linustechtips.com/topic/10079-second-power-supplier/#findComment-109064
Of course it is possible. You have an image of it. The question is, what do you need it for? You will need to mess about a bit with the 20 pin connector, and while it isn't the most complicated thing to do, it might just be unnecessary. You're better off getting a new PSU with a higher wattage (there are plenty with 1500+ W around these days, which is enough for four Titans on an X79 platform)
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/10079-second-power-supplier/#findComment-109079
https://linustechtips.com/topic/10079-second-power-supplier/#findComment-109086
As said, all you need to do is get an adapter of some sort to jump start the second one as you turn the computer on. Power supplies just convert the 240v AC current to low-voltage DC current, it's not controlled via software or anything so adding a second one isn't a problem.
That said, be careful to balance the power usage between the two units if you do that. Because of how power supplies work, you need to have a certain amount of load on both the 12v and 5v rail, else you can get really high fluctuations of voltage if you just pull from the 12v rail exclusively. Estimating the wattage each component needs is also important, to know how to balance the units equally.
As everyone else said however, there's really no need for it. Even a dual-Xeon setup with dual Titans will be fine with a 1600w unit. Only time it might be useful would be for an extreme workstation/number crunching setup, but in that case it'll probably be easier to get multiple systems instead.
https://linustechtips.com/topic/10079-second-power-supplier/#findComment-109117
Yes it would work but I think for your second psu you would need to short the motherboard pins to start the psu. Corsair has a youtube video about testing your psu by shorting the pins: www.youtube.com/watch?v=5FWXgQSokF4
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/10079-second-power-supplier/#findComment-109454
