1. I was wondering what the optimal way is to undervolt my RTX 2070. I have a Zotac RTX 2070 blower edition so I need to keep my GPU cooler without sacrificing performance.
2. Is there any AIO GPU cooling solution out there for RTX 2070 reference designs?
https://linustechtips.com/topic/1007851-gpu-undervolting-liquid-cooling/
1. I guess the voltage frequency curve in MSI Afterburner (EVGA PrecisionX has a similar function, only less detailed)
2. Kraken G12 should still fit
Desktop benching:
I tried undervolting with MSI afterburner. Set 1890Mhz at 950mV. There weren't any crashes but I have started to notice stutters in some of the games.
Kraken G12 doesn't list 2070 as a compatible card. Are you sure?
What about the latest EVGA hybrid cooler they announced. They say reference 2070s are not supported. So kinda confused. My card runs pretty hot.
Did you run stress tests on your settings?
On 12/13/2018 at 7:24 PM, thorswrath91 said:
Yes. Ran Unigine heaven on loop for 15 minutes and did Timespy 5 times. It seems stable. But somehow it doesn't lower the temps that much compare to the stock voltage profile.
What case do you have and how many fans?
