Motherboard help
Go to solution Solved by Ben a cava,
Just now, Overbuilder said:
Wish i had RGB in my pc... Maybe one day.
Thanks so much have a very enjoyable Christmas
Does anyone know if the ASUs b450m - k atx 4 motherboard supports led 5050 pins as I can’t find it anywhere
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/
1 minute ago, LukeSavenije said:
5050? what do you want to connect?
Led strip light
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076388
Also, please refrain from asking the same question twice in the same hour
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076391
2 minutes ago, LukeSavenije said:
which one?
Any that will fit
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076397
3 minutes ago, Olllllli said:
For what it is worth, I don’t have this board, but I looked at the specs and could not find it listed, nor when looking at the photos could I see one. But that’s just from observation so I may be wrong.
me neither. the only leds i see are in the audio pad. This is more of a home theatre board as far as I can see
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076433
8 minutes ago, LukeSavenije said:
as far as I know non-aura motherboards don't have a rgb header. And that motherboard is cheaply made in general. no vrm heatsink for example
Could you recommend a motherboard ?
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076452
Could you recommend a board
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076453
Just now, LukeSavenije said:
well, there are so many for so many different people. what is your budget, location and what do you want to do with it?
I’m from uk, my budget is under £90 and I just want to game with a bit of schoolwork too. The system will have a razed 5 2600 and gtx 1070
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076466
Tbh no, not really, I am more of an intel sorta guy. I hear a lot of people talk about the b450 tomahawk from msi, which a quick check reveals it to have 2 5050 12v rgb headers (double check this), but I have no idea on how the motherboard performs.
Other than that, the 5050 connectivity is usually listed under “internal IO” or “internal connectivity” or something of the nature, in the mobos specs.
Edit: ^if you want to search for one yourself.
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076471
well, the pro4 is unbeatable for the price, only 60 bucks. with vrm heatsink, great vrms, enough io, much better than that asus prime board
tomahawk is great too, but a bit above your budget
fatal1ty is a recommendation
and to end, the aorus elite if you want rgb lighting on the cheap
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076476
Aha thanks I was just looking at the tomohawk rn
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076479
Will look at that thanks
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076481
5050 is 12 volt? that makes it much easier to search. most synced boards (aura, mystic, fusion, polychrome) have that header
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076482
supports RGB LED strips in 7 colors though of you want cheap RGB and don't need a super great board.
What’s the board called ?
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076507
GA-AB350M-DS3H from gigabyte.
Thanks
PSUGigabyte P650B
https://linustechtips.com/topic/1007791-motherboard-help/#findComment-12076510
