on the back of my motherbord i have
L R 3.5mm jack
C Sub 3.5mm jack
RL RR 3.5mm jack
SL SR 3.5mm jack
And in my audio controle panel there is a option
Center/LFE Speaker
Swap Center/Sub Output
Just wanted to know what they all did. Thanks
Edit- And in my Audio options there is a option for Digital output (S/PDIF) wanted to know the difference between that and Speaker/Headphone options.
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/100773-audio-jack-question/
LR 3.5mm is stereo (normally green plug, same as on a phone/mp3 player/normal headphone jack)
C/sub is center and sub speakers in a surround sound configuration.
RL/RR is rear left and rear right in a surround sound configuration.
SL/SR are surround left and right in surround sound configuration.
Center/LFE actually has no affect on the center speaker, but are the low frequency effects for a sub
swap center/sub. Some surround systems use opposite poles in the connector for sub/centre so if by any chance your sub is playing normal center noise and your centre is playing normal sub noise you would use that option.
(Digital) S/PDIF controls optical output, headphone/speaker controls analogue output (3.5mm connectors)
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/100773-audio-jack-question/#findComment-1347933
Im sorry if i sound dumb but i still dont understand the last one S/PDIF xD thanks for the other info tho
https://linustechtips.com/topic/100773-audio-jack-question/#findComment-1347942
S/PDIF can either be Optical (Little square plug with a red light shining in it) or a coaxial connector (round rca style plug, typically orange)
so they are other plugs beside the 3.5mm jacks that are still for audio. Different sound systems may use a different connector not just the 3.5mm type.
optical-digital-audio-connection.jpg<---- these connectors do surround sound with just 1 plug
Micro-plugs.jpg<--- This style requires separate connectors to achieve the same output.
https://linustechtips.com/topic/100773-audio-jack-question/#findComment-1348035
Ah ok :P thanks
https://linustechtips.com/topic/100773-audio-jack-question/#findComment-1348049
  • 1 year later...
might get banned for bumping a old post but meh. im kinda curios i have a 2.0 stereo system and i want to add a sub to my setup. will i have to buy some 2.1 kit that has the orange plug or can i just use a 3.5mm to rca adapter to wire up a sub using the rca ports on back like what a polk psw 10 -psw110 or a cerwin vega xd8s has.
https://linustechtips.com/topic/100773-audio-jack-question/#findComment-5393465
