Posted December 10, 2018 So, I recently put in some new RAM into my computer. G.Skills Trident Z RGB 3600 18CAS RAM 16 Gigs (2x8) Since I put them in, my system has been a little off. Sometimes upon boot up, it'll shut off and reboot automatically. It'll do this anywhere from one to five times before it finally boots up properly. Games crash at random. I ran Windows Memory Diagnostic and it says I have a memory problem and to contact the computer manufacturer. Is there a way to fix this, or is the RAM faulty? System: Ryzen 1700X CPU MSI X370 Gaming Pro Carbon Mobo I have the RAM setting in the BIOS to the recommended speed, timing and voltage. Link to comment https://linustechtips.com/topic/1006362-i-have-a-memory-problem/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2018 Is that RAM on the QVL for your motherboard? First-gen Ryzen motherboards--especially MSIs--were a pain in the ass about which RAM they'd take and which they wouldn't. If your RAM speed is set to 3600, try dropping it to 3200 and see if that helps. I enjoy buying junk and sinking more money than it's worth into it to make it less junk. Link to comment https://linustechtips.com/topic/1006362-i-have-a-memory-problem/#findComment-12062576 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2018 1 minute ago, aisle9 said: Is that RAM on the QVL for your motherboard? First-gen Ryzen motherboards--especially MSIs--were a pain in the ass about which RAM they'd take and which they wouldn't. If your RAM speed is set to 3600, try dropping it to 3200 and see if that helps. Or rather under 3000mhz, the first round of ryzen processors were a total bitch to get above 3000mhz successfully Community Standards || Tech News Posting Guidelines ---======================================================================--- CPU: R5 9600X || GPU: RX 9070 XT|| Memory: 32GB || Cooler: Peerless Assassin || PSU: RM850e|| Case: Lian Li A3 Link to comment https://linustechtips.com/topic/1006362-i-have-a-memory-problem/#findComment-12062582 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2018 Just now, Slottr said: Or rather under 3000mhz, the first round of ryzen processors were a total bitch to get above 3000mhz successfully I was able to get to 3200MHz on AsRock boards pretty consistently, although it took some really janky voltages and really bad timings on their lower-end boards to do it. Ditto ASUS, never had a problem getting to 3200. MSI boards were just a bitch in general for RAM compatibility. Even if it was B-Die on the QVL, there was no guarantee it would actually POST. I made a point of avoiding Gigabyte boards after my original AB350M-Gaming 3 turned out to be a total pile of shit with more money spent on integrated RGB than on the damn VRMs. For what it's worth, the Corsair LPX DDR4-3000 RAM I bought for that board had to be run at 2800, because it refused to POST at 3000 no matter what I did. I enjoy buying junk and sinking more money than it's worth into it to make it less junk. Link to comment https://linustechtips.com/topic/1006362-i-have-a-memory-problem/#findComment-12062595 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2018 Author Hey thanks everyone. Dropping the speed down to 3000 seemed to do the trick. Link to comment https://linustechtips.com/topic/1006362-i-have-a-memory-problem/#findComment-12062655 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
