RX 580 isnt being used in games there for giving me low fps in easy to run games like league and overwatch, the usage jumps to 100% every so often and then my fps shoots up but it always goes back to 0-10%. I installed and reinstalled drivers about 4 times now and my cords are plugged in right no over clocking.
my cpu is at 60%-80% usage when in the games too.
when i used after burner and turned unified gpu, it didn't effect any game play but instead of the spikes in gpu usage its a constant 0%
Ryzen 5 1400
16 gb ram
RX 580 gb
600W gold psu
https://linustechtips.com/topic/1005972-rx-580-only-using-0-10-usage/
Sounds to me like a CPU bottleneck. Whats your CPU usage, as well as are you overclocked?
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
58 minutes ago, Teddyslayer36 said:
the cpu is OC to 3.6, but I dont think the cpu would bottle neck the computer where i cant even run league
Cpu usage in game is 60-80
 no overclocking on GPU
temps are all under 80 while under load too
Check which process use the most CPU. Doubt LoL need that much CPU power.
