7 minutes ago, OreoPandas said:
I'm typing ' twice. If I do (Shift + ') it makes *
Like I said, typing ' twice is not the same as ".
Maybe try shift + 8, seeing as shift + ' prints an *
If you're trying to print something with quotation marks, then this might help
#You can use an \ before the second quotation mark so that is prints sentence with them.
print("\"Example\"")
#This is how the example above prints
"Example"
#Or you can use these methods
print("\'Example\'")
print('\"Example\"')
https://linustechtips.com/topic/1005830-python-beginner-help/#findComment-12058223
"Example"
7 minutes ago, Minbari said:
You need to find your keyboard shortcut for the real dual quotations symbol- two singles together will never be the same thing.
Seems to be Shift + 2 for me. Thanks guys!
https://linustechtips.com/topic/1005830-python-beginner-help/#findComment-12058241
So much confusion about " because he has the British keyboard layout xD
i7 8700K CPU | Gigabyte 1080 TI Turbo Graphics Card | Asus Z370-A Motherboard | 2 x 16GB Vengeance LPX Memory |  Samsung 1TB 970 Pro SSD | WD Red 6TB & WD Green 3TB HDDs | Be Quiet! Dark Base Pro 900 rev.2 Case | EK Monoblock + Bykski Graphics card Waterblocks EK 420 PE + 420 CE Radiators | 6 EK Furious Vardar EVO 140 BB Fans |  Enermax Neochanger 200ml Reservoir & pump
https://linustechtips.com/topic/1005830-python-beginner-help/#findComment-12058258
