MOBO: Asus z270e
CPU: intel i5 7600k
Case: H500P
I'm a bit worried i might have done something wrong when installing my aio
my fans are connected to the fanspilters coming out of the pump, the SATA is connected and so is the USB 2.0. I got my 3 pins on the CPU fan (should I had it on the pump fan and if so where do I change it in bios)
It's idle around 30c but that is with full speed, I tried having it on normal but then the temperature just rises to 50 on idle. No overclock wish I find even more wired as I have had this CPU on 4.5 GHz easily with an air cooler cryorig h7
on load it has gone up to the 80-90c on full fan speed, does the back plate play a role in a certain rotation? thermal paste?
the fans are mounted on the top as exhaust
https://linustechtips.com/topic/1004256-help-with-h115i-pro/
3 hours ago, Zarous said:
MOBO: Asus z270e
CPU: intel i5 7600k
Case: H500P
seems like a bad mount of the cooler on the cpu
also can you confirm the pump is working?
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/1004256-help-with-h115i-pro/#findComment-12044386
