Hello Sylo,
Great idea to build your first Pc. To help you we will need more information, like what your planning to do with the system (gaming, editing, browsing the web, etc). It would also be helpfull if you gave us the budget you have for your new computer, or any particular preference (amd or intel, asus or gigabyte, prefered resolution, etc).
https://linustechtips.com/topic/1003848-pc-build-help/#findComment-12040594
