USD or CAD?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1003607-build-help/#findComment-12038010
There you go:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($159.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.99 @ B&H)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($129.99 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($72.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.85 @ OutletPC)
Video Card: MSI - Radeon RX 580 8 GB ARMOR OC Video Card  ($204.99 @ Newegg)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($98.98 @ Newegg Business)
Power Supply: EVGA - SuperNOVA G2 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($65.88 @ OutletPC)
Total: $892.66
Generated by PCPartPicker 2018-12-03 17:43 EST-0500
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/1003607-build-help/#findComment-12038012
Do you need a monitor and peripherals as well?
https://linustechtips.com/topic/1003607-build-help/#findComment-12038016
1 minute ago, Krosis said:
There you go:
Total: $892.66
Only thing I can add to this is to expand your storage even further if you're going to be playing games. 1TB gets eaten away too fast now, especially with mods.
The Meshify C case can also be had for less if you shop around, the NZXT s340 or h500 cases are good alternatives.
https://linustechtips.com/topic/1003607-build-help/#findComment-12038023
2 hours ago, DVA said:
What are you playing at? 1080/1440?
I am actually playing on nothing right now, to get it out of the way and to be fair, my brother is more on the tech side of things, I just wanna get more input and information for a decent-good gaming pc. Everyone is just so helpful right now, I actually feel bad for not knowing a lot of different type of builds. I’m so new to this that I don’t know even the best peripherals for a pc.
https://linustechtips.com/topic/1003607-build-help/#findComment-12038562
There you go:
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($87.99 @ Amazon)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: SeaSonic - FOCUS Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Monitor: ViewSonic - XG2401 23.6" 1920x1080 144 Hz Monitor  ($179.99 @ Amazon)
Keyboard: Cooler Master - MasterKeys Pro L Wired Standard Keyboard  ($99.99 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.00 @ Dell)
Total: $1149.76
Generated by PCPartPicker 2018-12-03 20:00 EST-0500
https://linustechtips.com/topic/1003607-build-help/#findComment-12038582
Motherboard: MSI - B450M PRO-VDH Micro ATX AM4 Motherboard  ($79.99 @ B&H)
Memory: G.Skill - Ripjaws V 16 GB (2 x 8 GB) DDR4-3000 Memory  ($109.99 @ Newegg)
Storage: MyDigitalSSD - BP5e Slim 7 240 GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Amazon)
Video Card: MSI - GeForce GTX 1070 8 GB Video Card  ($349.99 @ Amazon)
Case: SAMA - Maxcool-W-15LEDLight MicroATX Mid Tower Case  ($54.98 @ Newegg)
Power Supply: Rosewill - Capstone 650 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Keyboard: Gigabyte - FORCE K83 Wired Standard Keyboard  ($39.40 @ Amazon)
Mouse: Corsair - M65 PRO RGB FPS Wired Optical Mouse  ($29.99 @ Amazon)
Total: $1147.80
Generated by PCPartPicker 2018-12-03 21:42 EST-0500
https://linustechtips.com/topic/1003607-build-help/#findComment-12039038
