Power Supply Needed for Setup.
Go to solution Solved by Krosis,
I would say around 850W.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
Like @Krosis said, I would get an 850W power supply. The 1080Ti SLI is obviously going to use a lot of power. If you have a lot of RGB fans, RAM, or accessories of that sort, it won't hurt to have a bit of headroom with the extra wattage.
Think about future upgrades!
