Hi guys,
Here's the thing. My CPU is reaching up to 212°F (100°C), so, as you can imagine my PC just stops working (I have the default Cooler that came with the CPU).Then I decided to buy a new Cooler, but I have a question about that.
Which Cooler should i buy? (socket: 1151, Pentium G4400)
Consider this:
-Less than $40 or $50 dlls.
-Parallel to the CPU (horizontal).
-Something like the picture (Cooler Master, Vortex Plus).
I'll be thankful if you guys could help me.
BTW: I'm wanna change my CPU for a i5 7gen or something like that in a future.
Thanks. :)
Cooler Master Vortex Plus - Disipador de CPU con aletas de aluminio y 4 Heatpipes de Contacto Directo (RR-VTPS-28PK-R1)
https://linustechtips.com/topic/1003515-cpu-air-cooler/
Where are you shopping / located?
What case and ram are you using? Are you planning to oc later?
https://linustechtips.com/topic/1003515-cpu-air-cooler/#findComment-12037035
for a Pentium G4400 reaching 100c with a stock cooler...it sounds like a different issue
Sounds like the cooler is not making full contact with the CPU and/or poor thermal paste application
for reference, my i7-8700 would reach a max temp of 85c under load with a stock intel cpu cooler
Photography / Finance / Gaming
https://linustechtips.com/topic/1003515-cpu-air-cooler/#findComment-12037052
WoodenMarker: Hi, I'm from Mexico.
My case is a Acteck KIRUNA and I'm using a AData 1x8gb 2133mhz ram.
And no, I'm not planing in doing oc.
Mok: I think there's an issue with the thermal paste or the contact too... but actually, I was planning buy a new CPU Cooler so this is a "perfect" excuse.
And, some friend share with me the temperature of his CPU (same as me) and never reach anything over 80°c.
Thanks. :)
https://linustechtips.com/topic/1003515-cpu-air-cooler/#findComment-12037547
Can you link us to where you're shopping?
@JMojoe Make sure to use '@' and click from the drop down menu in order to properly tag other members. Quoting also works well if you have something specific you're replaying to.
https://linustechtips.com/topic/1003515-cpu-air-cooler/#findComment-12048895
