I basically wanna buy a PC but I don't know wich power supply to buy?!?!
Here are my PC specs: a I5 8600K, a GTX 1070ti AMP! Edition (from Zotac), 16 gbs (2x8) of TridentZ RGB 3200 (from Gskill) DDR4 RAM, a Corsair Carbide SPEC-OMEGA RGB case, a Asus Rog Strix B260-F Motherboard and a HP EX900                                          M.2 500GB PCIe 3.0 x4 NVMe SSD.
Is this PC would be good?
What's the best power supply for my PC (the cheaper, the better)?
*Must be on Newegg.ca*
Please tell me.
Thanks in advance.
-Arix
https://linustechtips.com/topic/1003141-wich-power-supply/
You haven't stated your budget, check out the Corsair RM550x
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1003141-wich-power-supply/#findComment-12033569
? B250 or B360? The B250 won't be compatible, and the B360 doesn't make sense.
As for the PSU, the Formula 450W costs $80. Good performance, rifle bearing fan, decently quiet fan curve, and multi rail.
https://ca.pcpartpicker.com/product/jfs8TW/bitfenix-formula-gold-450w-80-gold-certified-atx-power-supply-bp-fm450ulag-7r
Edited by seon123
Something something
https://linustechtips.com/topic/1003141-wich-power-supply/#findComment-12033587
