I recently got my hands on a 2.66 GHz Intel Core 2 Extreme QX6700, and i wanted to install that on my Gateway GM5483E with a 3.00 GHz Intel Pentium D 926, i did some research before buying the Core 2 Extreme, they were both the same socket (LGA 755), when i found out it was compatible i went ahead and purchased it, so far so good, after i swapped out the Pentium for the  Core 2 Extreme i booted up my computer and nothing happened, all i got was a blank screen, the fans and hard drive spun up but after a few seconds the shut down, and if i put the Pentium back, my computer booted up normally, i swapped them again and...nothing...the computer boots up with the Pentium but but not with the Core 2 Extreme,is there something i am doing wrong?
any ideas will be greatly appreciated.
motherboard: 945GCTt-M3 by ECS
Edited by CarlosC
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01100011 01100001 01101110 00100000 01110010 01100101 01100001 01100100 00100000 01110100 01101000 01101001 01110011 00100000 01110101 00100000 01100001 00100000 01100111 01100101 01100101 01101011
https://linustechtips.com/topic/1002745-pc-wont-start-after-cpu-upgrade/
Same socket doesn't mean compatible. There will be a compatibility list on gateway's site, and it doesn't likely include a CPU of that caliber
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, LukeSavenije said:
Is that motherboard even compatible with core2quads?
yes,i checked on the Manufacturers website and many others
BIOS version?
Primary PC:
PSU tier list
2 minutes ago, fasauceome said:
BIOS version?
Version 1.6, i don't really know how to upgrade the bios.
Updating is rather simple, there should be loads of online tutorials for you to refer to that would be loads more helpful than someone typing it
Primary PC:
PSU tier list
i will try to update bios, i'm going to keep my fingers crossed
after updating the bios still nothing, i pretty much gave up on this, i will probably find a proper motherboard for this thing,  however, thanks for trying to help
