I am planning my first PC build cause atm I have a laptop that is getting slow and old fast. The main uses will be gaming, and although I don't play many AAA or intensive games, I want a PC that is future proofed for at least a few years without needing to upgrade for a little while. I am in Australia and I don't want to be spending much more than $1000 AUD, although I don't mind stretching that a hundred dollars more or so if you guys feel its necessary, but I'd prefer as cheap as possible around $1000 exc. Windows (if you guys can make it even cheaper than that, even better). I will be playing games on a 1080p 60Hz display. Here is what I've got so far:
Any advice or tips much appreciated,
Thanks
https://linustechtips.com/topic/1002447-first-pc-build/
coming from an AMD fan boy, you can get a 1060 6gb for about the same as the rx580 with way more preformance. also you should spend the largest amount on your graphics card i would downgrade the cpu alittle and maybe spend alittle more on the gpu and get a good cooler to keep it working longer. also not sure if you have it added already but windows will run you about $140 Australian i think.
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028233
Thanks for the help, I have looked into the 1060 6gb but it will cost about $75 AUD more than the RX 580 8gb, do you think it will be worth that much extra?
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028242
i would down grade the cpu and use the saved money to get a 1060. you really dont need a super powerfull cpu to game in modern games the gpu matters more. i would maybe look at a Intel Core i5-7400 its a gen older but should still work fine + you can use the same mobo. but there is so much out there if youre willing to look.
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028262
Definitely not. A 580 is just as capable as a 1060. If you have any extra get an SSD. Trust me, booting of a HDD is a pain.
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028267
if youre willing to think about amd i have a ryzen 5 1600x and it works great no problems in any games i play. plus its much cheaper then intel
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028269
No, he cant use a B360 board with a 7th gen CPU.
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028270
PCPartPicker part list: https://au.pcpartpicker.com/list/8BbHLJ
Price breakdown by merchant: https://au.pcpartpicker.com/list/8BbHLJ/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($255.00 @ Skycomp Technology)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard  ($207.00 @ Shopping Express)
Memory: Kingston - HyperX Predator 8 GB (2 x 4 GB) DDR4-3000 Memory
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($118.00 @ Umart)
Video Card: Sapphire - Radeon RX 580 8 GB PULSE Video Card
Case: Phanteks - Eclipse P300 Tempered Glass (Black) ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($139.00 @ Austin Computers)
Total: $808.00
Generated by PCPartPicker 2018-12-01 21:31 AEDT+1100
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028284
also going to have to disagree the 580 just cant compete with nvidia. when you get into vega thats a totally different story but the lower gpus are not even close
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028287
1 minute ago, zzzoot said:
Doesn't include costs of RAM/GPU in the total price
PCPartPicker part list: https://au.pcpartpicker.com/list/qFhW7W
Price breakdown by merchant: https://au.pcpartpicker.com/list/qFhW7W/by_merchant/
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($133.00 @ Umart)
Storage: Western Digital - Green  240 GB 2.5" Solid State Drive  ($49.00 @ Umart)
Video Card: Gigabyte - Radeon RX 580 4 GB AORUS 4G Video Card  ($269.00 @ PLE Computers)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($78.00 @ Shopping Express)
Total: $1080.00
Generated by PCPartPicker 2018-12-01 21:36 AEDT+1100
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028294
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1060-6GB-vs-AMD-RX-580/3639vs3923
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028295
Total: $1080.00
What would you suggest for a cheaper mobo to make up for no hard drive lol
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028299
Just now, Jharring3050 said:
thats just an online guess youre going to get a ton of extra preformance becuase nvidia is just better at the game.
Well. I had both cards. Now I have a 1060. I used to have a RX 480. I am not an AMD fanboy, I am just trying to objectively show the performance. I independently benchmarked both of them and had results withing 5% of each other in multiple games. I don't mean to be hostile but  please, don't spread mistruth. We are both here to help someone build a PC not to argue about two same-class GPU's.
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028301
3 minutes ago, Konrad_K said:
If you need more storage I wouldn't go any cheaper than an Asrock B450 Pro. The price difference should let you get a 1TB hdd.
This one? https://au.pcpartpicker.com/product/dQgzK8/asrock-b450m-pro4-micro-atx-am4-motherboard-b450m-pro4
https://linustechtips.com/topic/1002447-first-pc-build/#findComment-12028308
