New build need help
Go to solution Solved by NunoLava1998,
100 pounds overbudget, but should be OK:
CPU: AMD - Ryzen 7 1700 3 GHz 8-Core Processor  (£148.80 @ Aria PC)
CPU Cooler: Corsair - H60 54 CFM Liquid CPU Cooler  (£60.46 @ Scan.co.uk)
Motherboard: Asus - ROG STRIX X470-F Gaming ATX AM4 Motherboard  (£187.46 @ CCL Computers)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£126.95 @ More Computers)
Storage: Samsung - 860 Evo 250 GB 2.5" Solid State Drive  (£46.79 @ Aria PC)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (£34.79 @ Aria PC)
Video Card: EVGA - GeForce GTX 1070 Ti 8 GB SC GAMING ACX 3.0 Black Edition Video Card  (£447.46 @ Scan.co.uk)
Case: NZXT - H500 (Black) ATX Mid Tower Case  (£69.59 @ Aria PC)
Power Supply: Corsair - RMx 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  (£85.00 @ AWD-IT)
Total: £1207.30
Generated by PCPartPicker 2018-12-01 08:13 GMT+0000
Hello, I’m looking to build my own PC soon with about £1000-1100 ($1276-$1400), now I’m fairly new to this but would prefer to build it myself and not pay the premium for using a website like pcspecialist, i’m not looking for any particular brand AMD or Intel just really the best performance I can buy for the money, as well as also water cooling (because come on, why not?)
Aim: Gaming
Monitors: 1
Peripherals: Corsair K95, Razer Naga Hex V2 (will need Windows)
Why I’m Upgrading: simply for the better performance and long-term value, currently I’m using a laptop that’s started to die a bit (Dell 15 7000) and it’s a discontinued model
Thanks for your help and attention it’s greatly appreciated.
Edited by cs117x
Adding information
https://linustechtips.com/topic/1002427-new-build-need-help/
Total: £1207.30
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028079
Total: £1207.30
slap a 2700 and reduce the x470 to B450, samsung 970 evo is cheap now, 1tb hdd is too low, get 2tb at least,
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor  (£221.47 @ Scan.co.uk)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard  (£79.97 @ Ebuyer)
Storage: Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive  (£63.54 @ Aria PC)
Storage: Hitachi - Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  (£85.00 @ Amazon UK)
Total: £1178.98
Generated by PCPartPicker 2018-12-01 08:23 GMT+0000
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028088
just gaming or with streaming/editing/rendering? need the monitor?
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028090
The 2700 is more expensive in the UK, and hey why not get a good X470 board? I'd rather get a high-quality X470 board and a 1700 than a B450 board and a 2700
1TB isn't low unless you have a lot of files
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028092
its low in today's standart. you will have lots of files eventually, one games is 30GB in average.
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028098
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£145.99 @ Aria PC)
Motherboard: MSI - B450 Gaming Plus ATX AM4 Motherboard  (£84.99 @ Amazon UK)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£113.48 @ CCL Computers)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  (£36.95 @ Aria PC)
Storage: Toshiba - 2 TB 3.5" 7200RPM Internal Hard Drive  (£51.97 @ Laptops Direct)
Video Card: MSI - GeForce RTX 2070 8 GB Video Card  (£469.79 @ Overclockers.co.uk)
Case: Game Max - FALCON WHITE RGB ATX Mid Tower Case  (£44.99 @ AWD-IT)
Power Supply: Cooler Master - MasterWatt 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£54.98 @ CCL Computers)
Total: £1003.14
Generated by PCPartPicker 2018-12-01 08:26 GMT+0000
you can get OS from reddit for $25 USD.
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028099
Unless you have a massive steam library, 1TB is definitely enough.
It's not like he's putting 7 copies of XPlane (100+ GB) on his HDD lmao
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028105
My steam library is fairly small I play about 5 games maximum the biggest is about 70 gb
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028109
2 hours ago, cs117x said:
Just gaming, the monitor is a Dell U2417H
In that case:
Video Card: Gigabyte - Radeon RX VEGA 56 8 GB Video Card  (£349.79 @ Overclockers.co.uk)
Monitor: AOC - G2590FX 24.5" 1920x1080 144 Hz Monitor  (£187.18 @ PC World Business) much smoother gameplay with freesync and higher refresh rate.
Total: £1070.32
Generated by PCPartPicker 2018-12-01 10:49 GMT+0000
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028311
15 minutes ago, cs117x said:
Just for clarification why would this be better ?
You'll be stuck at 60hz 1080p with your current monitor while getting a 144hz monitor will make your gameplay much smoother.
https://linustechtips.com/topic/1002427-new-build-need-help/#findComment-12028378
