Count chokes on the left and above of CPU (little cube thingies). If top and left side has 4 chokes each, that is 4+4 phase power delivery. For 1600, 4+4 is enough.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1002091-power-phase-count/#findComment-12024969
Check reviews or lists of collated information. You cannot tell from the spec sheet as they often lie, nor from pictures as they often use fake phases.
Here's a partial VRM list for Ryzen boards.
No, that does not work. The number of phases can easily differ from the number of chokes.
https://linustechtips.com/topic/1002091-power-phase-count/#findComment-12024976
What about the Asus B350-K? It has 4+2. Is this enough? I have a tight budget
https://linustechtips.com/topic/1002091-power-phase-count/#findComment-12024979
