Building my first pc!
Go to solution Solved by Eastman51,
1 minute ago, Melvi said:
ok, so it says (OC 4266MHz) doea that mean i can overclock it ?
If that is whats in your motherboard manual, then that means that 4266MHz is the theoretical highest clock speed you OC RAM to.
Edit: To OC RAM, go into your BIOS and it should be right there. Your manual may also tell you how to do so
i think it just caps it.. so if you have the 3000mhz ram it wont run at full but i think it should work
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022236
-Moved to CPUs, Motherboards, and Memory-
So i just bought my parts and i discoverd that the motherboards standard ram is 2666MHz and i bought 3000MHz. Does it still work or do i have to buy 2666MHz ram instead?
Your motherboard will automatically run your memory at 2666Mhz. You will have to manually overclock your memory to reach 3000Mhz.
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022247
DDR4 has a base speed of 2666MHz, DDR4 can be specced for higher clock speeds, but they don't run higher than 2666MHz by default. If your motherboard only supports 2666MHz RAM, then you just won't be able to increase your RAM clocks up to their rated max speed.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022255
ah ok , so i can overclock the ram higher even if it says standard 2666mhz
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022266
Motherboard speed support is native. It support anything between DDR4-2133 and 2666 just fine, but you can manually overclock to go higher. Some will even go as high as 4233 or something crazy like that.
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022275
Correct.
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022277
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022280
*GPU Test Bench*
https://linustechtips.com/topic/1001801-building-my-first-pc/#findComment-12022284
