Audio Passthrough?
I'd pick up these:
https://www.amazon.com/gp/product/B076GDVWG4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://www.amazon.com/J-Tech-Digital-Extractor-Converter-Passthrough/dp/B074HHSJVN/ref=sr_1_6?ie=UTF8&qid=1543597756&sr=8-6&keywords=hdmi+2.0+switch+with+audio+out
Run whatever you want into the switch, through the audio extractor and then into the monitor, the extractor gives you analog and digital audio output. You can find a switch that handles both the function of switching and audio extraction but I have yet to find one that has proper EDID functionality, I run this combo for my consoles / a few other devices and it works perfectly.
Both devices are HDMI 2.0 so you shouldn't run into any bandwidth issues for the foreseeable future.
