So, I am working on building my first pc, but I forgot to research whether or not things are compatible or not. I am going to attach a link of the parts I got (keep in mind I have a case already) And please tell me if it would make an ok pc. I figured this would be a good place to go.
https://gyazo.com/4d8da0632b25389c38e8f065f98136dd
https://linustechtips.com/topic/1000543-building-my-first-pc/
Solid system.  As stated, the GPU will be bottlenecked a bit.  You should be able to play most games at high settings.  Ultra settings might bog down a little bit or trying to run 1440p.  Still should be fine at 1080p.
CPU:   Ryzen 7  5800x      CPU Cooler: Corsair H115i Pro       Motherboard:  Asus x570 TUF Plus      Memory:  64GB Corsair Vengeance DDR4-3600
GPU:  ASUS TUF RTX3080        SSD: Crucial P5 1TB  PCIe NVMe  Samsung 990 Pro 2TB           PSU: Corsair CX750       Case: Thermaltake View 71 TG RGB
Monitors: LG 34" Ultrawide    Samsung 28" 4k
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010825
4 minutes ago, ShadySocks said:
Looks good to me, but GPU bottlenecked
Do you mean the GPU is too weak or the CPU is too weak? Either way it's not really a problem. There's always going to be a bottleneck of some variety.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010828
This is a relief to hear. My monitor is 1080p anyways so it works out fine. I was just mostly worried about the ram and psu
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010829
4 minutes ago, ChaoticKam said:
What does that mean?
GPU limiting game performance rather than CPU. I won't be too bothered with it
Desktop benching:
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010833
Good build. One of the better ones I've seen.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010837
6 minutes ago, ChaoticKam said:
So do you think I will have a problem with flight simulations?
I don;t think so
btw the motherboard's the disappointing part, I won't be overclocking the CPU with it.
Desktop benching:
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12010864
1 hour ago, ChaoticKam said:
The thing is i have a Micro Atx case. What is disappointing about it?Should I cancel and get another
Asus only makes expensive good boards. Cheap boards get really cheaped out VRMs, especially important when it comes to handling an 8 core CPU
Desktop benching:
https://linustechtips.com/topic/1000543-building-my-first-pc/#findComment-12011996
