really need help here
Go to solution Solved by Crunchy Dragon,
-Moved to Programs, Apps, and Websites-
in details shows 34.230.224.115 and i opened its this page .imp.thumb.JPG.44e9fa965ddd90a34a0dbae3696423e1.JPG
i believe that the last time i installed videodownloader.ummy.net its a internet video downloader  and that was a big mistake it was a russian developer and intalled some other programs i cleaned up the pc in regedit and cleaned temp files and anything that i knew its just this one remaining and i really cant find what is trying to connect i have Glass wire doesnt show it cause before anything happens eset blocks it. (programs that run after logging in are safe)   : )   @VegetableStu
https://linustechtips.com/topic/1000150-really-need-help-here/#findComment-12007690
2 hours ago, VegetableStu said:
does it say anything more when you click "Details"?
I was about to suggest running netstat -ban in command prompt to see which program's trying to connect there, but that'll need the offending program connecting to that IP first ._.
speaking of which, what were the last few programs you've been installing? (probably narrow down to programs that run after logging in)
it was the Nord Vpn i dont know why but i turned off start with windows then i restart the pc the no pop up till i opened the  nord vpn @VegetableStu
thank you :)
https://linustechtips.com/topic/1000150-really-need-help-here/#findComment-12007936
https://linustechtips.com/topic/1000150-really-need-help-here/#findComment-12008274
