Posted November 17, 2014 I need to get a good mic that isn't a headset that will work with my PC.I'm going to be using it to live stream console games, since my PC gaming headset won't work with my PS4 or PS3, and my PS4 and PS3 headset works like crap on my PC. So basically I'm looking for two types of mics.....1. A mic that clips on my shirt (which might be the best option)2. One that sits on my desk in front of me.I have zero experience using either of these styles of mics simply because I've always had my mics on my my gaming headset.The mic has to make my voice sound clear with no crackles and what notThe mic has to be a good noise canceler (I have a TV running and usually a couple people talking behind me 25 ft away in the same room) Also if it's a shirt clip mic, wireless (if possible) is preferred. If you guys can you guys point me into the right direction of mics I would appreciate it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 17, 2014 Sorry I could only help you if you needed two turntables. Too many ****ing games! Back log 4 life! :S Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 17, 2014 Tek syndicate latest video http://youtu.be/3fD-M1F6L4g?t=17m40s But it isn't very good at noise cancelling according to what they said. ﷲ Muslim Member ﷲ KennyS and ScreaM are my role models in CSGO. CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
