Strange problem with ethernet cutting speed on my PC
29 minutes ago, NuSigMu said:This is a fun one. Its hard to troubleshoot the exact cause due to it being related to only specific sites and applications. From first glance it sounds like a routing issue. What websites are you experiencing the issues with? Can you run a tracert to one of them and see how many hops you get? What DNS provider are you using?
Problem has been solved. I will write what the reason was, I hope that if someone has this problem, he will find the answer in this forum, personally I found the only answer on the internet that proved to be completely satisfactory and it was the only one post on the Polish forum. This problem causes Windows 10 as I suspected. I have been looking for the problem for two months. Windows 10 QoS packages are to blame for this. To fix this problem, go to gpedit.msc in the search engine and then go to "Windows settings" and then right click on "Policy based QoS" and select "Advanced QoS settings" and then check the unchecked "Specify the level of TCP receiving rate" option, then you need to select the level of the maximum rate, i.e. level 3. After using this option, the speed tests immediately showed 500Mbps, and Origin began to download at speeds over 50MB / s.
