  • entry
    1
  • comments
    8
  • views
    1,087
8 Comments
Prastupok
Posted
I tend to lean on the side of caution... I'd say at least 650w, I personally would go 750 or 800 for headroom. Some may disagree.
Carnoustie14
Posted
NONONO, Dont go galax card. I would go EVGA or Gigabyte
They are just better cards.
EVGA 980 Classified if you have the budget
batpanda
Posted
i run the rm 850 from corsair with your config 850 is more than enough :)
MblaZe7run
Posted
Use just about any PSU wattage calculator then add about 20% on to that for decent overhead and coverage from capacitor aging.
