Well it all depends on your game library or use case, I'd recommend a Ryzen 5 2600 or an i5 as of now, but it's not unreasonable to pair it with an i7 or a Ryzen 7 as your workload demands.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/999834-rx580-8gb-max-cpu/#findComment-12004770
my main game is   blops4  and blackout
i dont do anything else  then game on my pc
https://linustechtips.com/topic/999834-rx580-8gb-max-cpu/#findComment-12004774
A mid range CPU will be suitable then. A low end CPU would suffice as well, but Black Ops 4 likes CPUs with more cores and threads, so a Ryzen 5 is my recommendation.
Primary PC:
PSU tier list
https://linustechtips.com/topic/999834-rx580-8gb-max-cpu/#findComment-12004961
