Best thermal paste?
Go to solution Solved by Draakje,
Just now, KingCry said:
I used IC Diamond, NT-H1, AS5 and the Kyronaut. Temps with the Kyronaut is better overall on CPU and GPU, I'm seeing peaks of around 46C on all cores for CPU and GPU a peak of 60-62C with a fairly quiet fan cure.
Alright, I'll give the Kyronaut a try then. Thanks
Looking for a good thermal paste that works with medium overclocking and that is idiot proof, budget is unlimited (within reason, not paying 300 for thermal paste of course).
Currently looking at the Noctua NT-H1, but open to any suggestions/anything that works better/is higher end.
https://linustechtips.com/topic/999734-best-thermal-paste/
Thermal Grizzly Kryonaut, it doesn't dry up and is non conductive.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12003769
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12003782
2 minutes ago, Draakje said:
That's the one, I've been using it since it was available in the UK and had to get some shipped over to me.
|King Of The Lost|
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12003793
1 minute ago, Draakje said:
Good temps? And what about temps compared to the Noctua NT-H1?
|King Of The Lost|
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12003819
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12003821
It is a bit hard (or expensive) for me in Asia to get products from Thermal Grizzly. Now I had a tube of Cooler Master master gel pro. But they just dry very fast and just didn't perform very well.
Is the artic XM-4 or AS5 good enough? Or there is something else in the market that work reasonably well?
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12006798
https://consumer.dow.com/content/dcc/en-us/category/industry/ind-pcb-systems-assembly/thermal-gels.html?utm_source=Google&utm_medium=cpc&utm_term={keyword}_{matchtype}&utm_campaign=DC2018SEM_North-America_PCB-Systems-Assembly_Thermally-Conductive-Materials_Thermally-Conductive-Gels_Google&gclid=EAIaIQobChMI8O7o-o7y3gIVg5JbCh0i4QPXEAMYASAAEgIIhvD_BwE#
I don't know where to buy any, but if you want the best you should technically start looking into as close to or into industrial levels as possible. Probably cooling solutions too.
You can probably get small amounts for cheap or free. There are always means!! ?
https://www.google.com/search?q=industrial+thermal+compound&ie=utf-8&oe=utf-8&client=firefox-b-1
I wonder how this would do compared to normal CPU compounds for home computer use?!
https://www.amazon.com/Corning-Heat-Sink-Compound-White/dp/B00JFJVS58
NVM: http://www.tomshardware.com/answers/id-2104991/cpu-thermal-paste-thermal-conductivity.html
Didn't read it all but apparent testing of said T340: https://pressf1.pcworld.co.nz/showthread.php?52362-CPU-temperature-results
If you could find some nice non conductive industrialist thermal paste. I wonder if you could just dunk the PC/motherboard on a breadboard into the a bucket of the stuff and use it like a makeshift mineral oil tank. (hint hint to linus and friends.) ?
The only other suggestion is find similar industries that produce similar or more heat and friction in the process of working...
I have no idea what or if any of these are applicable: https://www.google.com/search?client=firefox-b-1&q=high+temp+heat+sink+compound&sa=X&ved=2ahUKEwjL1NiPkPLeAhVLneAKHW1mDm4Q1QIoBXoECAAQBg&biw=1216&bih=569
I don't nkow if I'm allowed to say this but in real world engineering never think an idea is too odd because sometimes it's the last vestiges of something that used to be use elsewhere. But you could look up lubes from places like the porn industry. Or things like big oil. They have a lot in common. There are many more examples. That is if you want to be really thorough though.
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12007654
Occam's razor...all things being equal, usually the simplest answer is the correct answer.
Never rub another man's rhubarb!
4.2225Ghz 1700x on air
cpu-z validation
https://linustechtips.com/topic/999734-best-thermal-paste/#findComment-12012644
