Pacman Issue on Arch Linux
Solved by Sauron,
10 minutes ago, ArchTorvalds said:I'm using VMWare. The network adapter is NAT. How to fix this?
Did you just finish your installation, or did it work before and now it doesn't? If you just finished your installation, simply enable the dhcp service:
sudo systemctl start dhcpcd sudo systemctl enable dhcpcd
