Help for gaming rig
Go to solution Solved by Firewrath9,
PCPartPicker part list: https://es.pcpartpicker.com/list/ms7kmq
Price breakdown by merchant: https://es.pcpartpicker.com/list/ms7kmq/by_merchant/
CPU: AMD - Ryzen 7 1700 3 GHz 8-Core Processor  (€165.99 @ Amazon Espana)
CPU Cooler: ARCTIC - Freezer 33 CO CPU Cooler  (€29.62 @ Amazon Espana)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (€76.59 @ Amazon Espana)
Memory: ADATA - XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-2666 Memory  (€129.04 @ Amazon Espana)
Storage: Patriot - Burst 480 GB 2.5" Solid State Drive  (€59.99 @ Amazon Espana)
Video Card: Zotac - GeForce GTX 1060 6GB 6 GB AMP! Edition Video Card  (€239.99 @ Amazon Espana)
Case: Aerocool - QS-240 MicroATX Mid Tower Case  (€34.86 @ Amazon Espana)
Power Supply: Cooler Master - MasterWatt 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€64.70 @ Amazon Espana)
Total: €800.78
Generated by PCPartPicker 2018-11-23 21:13 CET+0100
Hello, I come here yet again looking for the knowledge of the best.
A friend of mine is looking to make a gaming PC, budget cannot go over 800€
He doesn't have any preference for platforms, in cpu and gpu. It can be anything.
The build needs:
Case, mobo, ram, gpu, ssd, hdd, aftermarket cooler (if possible), psu and i think i dont forget anything.
Thanks in advance.
https://linustechtips.com/topic/998869-help-for-gaming-rig/
Total: €800.78
https://linustechtips.com/topic/998869-help-for-gaming-rig/#findComment-11997996
Total: €800.78
Thank you very much, my friend will be very happy with this. I really appreciate it.
https://linustechtips.com/topic/998869-help-for-gaming-rig/#findComment-11998008
