FiiO E10k not detected
So I bought the DT990 headphones with the FiiO E10k Dac / Amp. I’m pretty new to this. I was using a gaming headset from Razer prior to this.
So, when I connect my E10k through usb nothing happens. I’ve tried different ports, different cables even. Nothing. A driver installation wizard is supposed to show up and yet nothing happens. Going to my playback devices I see no new device or anything.
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/
9 minutes ago, Kibelok said:
Okay, have you tried checking Device Manager to see if it shows up there, maybe an exclamation mark? Also make sure the cable is actually attached behind it, it can become loose fairly easy.
Firstly thanks for taking the time to help. Yes i did. Not on device manager either. I searched under audio devices. But there was no other devices section which makes me think it is not there. The light turns blue when I plug it so it’s probably not dead. Maybe an interference with some software on my machine? I don’t really know. I restarted several times just in case but no success there. Any ideas?
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11985924
Honestly, no idea. Try posting it here for someone at Fiio to actually help you: http://fiio.net:8000/forum.php?mod=forumdisplay&fid=65
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11985950
@Fibeus
You need to install Fiio control panel.
i use a FiiO X3K, u need the software installed and the DAP switched ot DAC mode.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11985962
2 minutes ago, SolarNova said:
@Fibeus
Since I’m not getting a popup to install this software when I plug the E10k is there a download link for me to do it manually?
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11985970
Ok nvm think its slightly different than my DAP setup.
All i have seen is som1 recommend unplugging ALL usb devices from your computer, then plugigng inth E10k and see if it then recognises it.
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11985993
3 minutes ago, Kibelok said:
will try this one once I’m home. Thanks.
@Kibelok posted a link that seems to be specifically for my model. So I guess that might help. Ill try it and let you know!
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11986003
Try the driver download on this page
https://www.fiio.com/e10kfaq
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11986010
Just to conclude here, I was at work when I asked the question here, and I had left my FiiO connected to my pc when I left. When I came back It had installed drivers and it was recognized in playback devices without me having done anything. Its working perfectly ever since! Thanks for your input anyway guys. Cheers.
https://linustechtips.com/topic/997333-fiio-e10k-not-detected/#findComment-11991287
